after enabling vlan on station I can’t access it via web (or ssh) v1.2.3.
Would it be possible to increase mtu by 4 bytes automatically when you enable vlans?
Also, I’ve set 1550 mtu on v1.0.3, did a soft upgrade to 1.1.7 and to 1.2.3, seems like the settings are not saved.
There probably is no way now to change the station mtu remotely, right?
ping 10.50.2.112 do-not-fragment size 1468
PING 10.50.2.112 1468 data bytes
1476 bytes from 10.50.2.112: icmp_seq=1 ttl=64 time=20.2ms.
1476 bytes from 10.50.2.112: icmp_seq=2 ttl=64 time=20.6ms.
1476 bytes from 10.50.2.112: icmp_seq=3 ttl=64 time=20.7ms.
1476 bytes from 10.50.2.112: icmp_seq=4 ttl=64 time=20.5ms.
1476 bytes from 10.50.2.112: icmp_seq=5 ttl=64 time=20.1ms.
ping 10.50.2.112 do-not-fragment size 1469
PING 10.50.2.112 1469 data bytes
Request timed out. icmp_seq=1.
Request timed out. icmp_seq=2.
Request timed out. icmp_seq=3.
Request timed out. icmp_seq=4.
