Multi Vlan Issues
Hello All,
I am running into an issue using multiple Vlans on a R200 with the most current non beta FW.
The Goal is to have Port 1-3 and the First SSID on a vlan, for example 1001, and be for only internet traffic. And the have Port 4 and SSID3 be only for video traffic on Vlan 66. Both with static IP's
I have ran through a couple configuration options with VLAN id's and SVLAN unsucessfully, and I wanted to start fresh and config as you folks suggest.
Currently I have the connection profile for the internet ports set to "INTERNET' for the service, and the STB/Video port set to "Other".
Thank you in advance
Hi ,
Please follow this article for configuring your R200 .  http://community.cambiumnetworks.com/t5/cnPilot-R-Series-Home-Small/cnPilot-Home-AP-configuration-in-bridge-mode-with-VLANs/m-p/113288#M42
If you still have issue , please raise a service ticket on https://support.cambiumnetworks.com/ .
Regards,
Nilesh
