Can I put 8 backHauls on same Tower & using CMM…? also possibly in Same direction…?
All the BHs must be set to master-mode and receive their sync from the CMM. The BHs can all be in the same band (e.g., 5.7GHz) if their DataDown% settings are all the same. Motorola recommends pointing same-frequency units in opposite directions, but this is to simplify coordination of frequencies between towers; I don’t believe it’s a functional requirement.
