Nanostation M5 brick after enable chose Spectral Analyser mode
Hello i flash XM nanostation with firmware 3.5.2, normal first binary file and 2nd upload .tgz archiv ... All look good, but i only check lb higher ping on nanostation (i meen that cambium use some priority qos for ping on device) ... All function work correctly.
But after i switch device to Spectral mode, and reboot it, but from this time device is inaccessible, no default IP 192.168.1.20, no 192.168.0.1, 192.168.0.3, no lease ip from dhcp, i try wireshark too .... without success.
I i power on device, i see red+orng. light together up, now +green and after sometime next green. After one minute i have on device power led on, lan led on, and one red led on .... And lan blinking - standard.
Cambium Discovery Tool without success.
Thank you for answer
Mirek
I miss i try reset hold with power on, reset wait one min, reset wait 2 min, reset only push, tftpd recovery with pc setup ip 192.168.1.10 and many other
Miroslav,
To recover N M5 unit you have to use UBNt procedure and flash it with their firmware first... We are not changing unit bootloader so use 192.168.1.254 on PC, TFTP accordingly then Elevate.
Rgds,
ePMPMaster
