Nanostation M5 brick after enable chose Spectral Analyser mode?
Hello i flash XM nanostation with firmware 3.5.2, normal first binary file and 2nd upload .tgz archiv ... All look good, but i only check lb higher ping on nanostation (i meen that cambium use some priority qos for ping on device) ... All function work correctly.https://showbox.bio/ https://tutuapp.uno/ https://vidmate.cool/
But after i switch device to Spectral mode, and reboot it, but from this time device is inaccessible, no default IP 192.168.1.20, no 192.168.0.1, 192.168.0.3, no lease ip from dhcp, i try wireshark too .... without success.
I i power on device, i see red+orng. light together up, now +green and after sometime next green. After one minute i have on device power led on, lan led on, and one red led on .... And lan blinking - standard.
Cambium Discovery Tool without success.
Thank you for answer
Please try to reach the radio on default local IP address - 169.254.1.1.
If it won't be reachable, please try to recover FW through the TFTP.
It's not a known issue. But if you will play around please take 3.5.6 FW.
Thank you.
