NAT PROBLEMS
I have enabled NAT on some of my Clients SMs.The client pcs are able to receive ip from the SM but unable to route to the internet.I have experienced this on all the SMs that I enabled NAT .I think there is a problem with this service .Anyway I am using 5.7Ghz radio with the 4.2.1 firmware.I am yet to upgrade to the 4.2.3.
Thanx.
Did you set the DNS IP address on the SM?
I ran into the same problem in my lab.
Alan
there is a problem in Sm you cant enable Nat and port filtering and DHCp at a same time we also get into this problem.
so you have to chose not all the tree things at a same time.
chose one or 2
Saud hassan
