Does anyone have a copy of the Antenna Radiation Patterns E and H
plane plots for the 5.7 gig antennas AP and SM.
Also interested in the same plots for the Reflector.
Thanks, Miles
miles@telecron.com
They seem hard to get a hold of. The best I’ve got is 60 degrees off the AP vertically and narrows the beam to 6 degrees with the dish. The new passive reflectors from equinox might have there specs on their website…have not looked yet! http://www.rfeq.com
Jason Duncan
CableAmerica Corp
480-461-6887 x222
Miles,
A radiation pattern for the standard 60x60 internal patch antenna can be found on page 8 of this Aplication Note: http://motorola.canopywireless.com/libr … t_Iss1.pdf
Hope this helps,
Chris
I would like to know does anyone have diagram for SM with reflector?
