Hi guys, i need the ePMP1000 below parameters, if you help me the below parametrs of the ePMP1000 i really appreciate it, :)
- What is the maximum height of AP - ?
- What is the maximum height of SM - ?
- What is the maximum distance between AP and SM - ?
- Should there be a direct visibility between AP and SM’s -?
Two suggestions for you. First, you can download the complete specifications, including dimensions, of the ePMP product line from http://www.cambiumnetworks.com/products/access/epmp-1000/
Second, to evalate performance I hughly suggest use of LinkPlanner. LinkPlnaner is free and can be dowloaded from http://www.cambiumnetworks.com/products/software-tools/linkplanner/ (near the bottom of hte page). LinkPlanner will allow you to quickly evalate different installation scenarios and provide very accurate performance expectations.
Best,
Scott
