I need help how the easiest way to allign both antenna, is there any trick beside look for the degree.
untill now my link still not connect, but, when i try in the lab, both are connected, so the problem in pointing, but until now link still down.
use link planner to know spected recived signal,
try other frec,
how much interference is there?
interference is arround -97 in slave side, in master -87dB
Calculation in Link planner is good
