Hi all, I am new with Cambium devices; I must deploy a PTP link in 13 or 15 or 18 GHz, distance between the sites is about 0.34Km, Line of sight is 100%.
Which products (Backhaul + integrated antenna or external antenna, all accessories…) could I use and where could I get them?
Thanks for your help.
Hello N’Guessan,
Would you give me the capacity you want to transport?
For that short distance, 0.34 Km (340 meters), I can advise you the 18 GHz band on the PTP 820S radio with 0.3 m dishes. I has a maximum capacity of 500 Mbps in one direction. This will work well in any weather as the link are very short.
Let me know the capacity and I will advise you further and also precise the location (Continent, country) if possible.
Sincerely yours,
Niragira Olympe
Thank you very much Olympe for your help.
So we need 2x PTP 820s and 2x 0.3 dish antennas. What about accessories…?
This capacity of max 500 Mbps in one direction will be good for us.
We are in Abidjan Cote d’Ivoire West Africa.
Hello N’Guessan,
You require as accessories:
- Outdoor CAT5e outdoor cables and power injectors to power the radios and their surge protectors
- Activation key for the needed capacity (500 Mbps)
- Grounding kits for IDU, outdoor cables and few glands for the PTP 820S ports.
Sincerely yours,
Olympe N.
Hi Olympe,
Thank you very much for your help. I’ll contact a distributor for an invoice.
Regards
Hello Mr. N’Guessan,
you are welcome.
Sincerely yours,
Niragira Olympe
