I have a 900MHz 450i AP running v16.0.0.1. This has been deployed for 2 months and only have 5 SM's on it so far.
I am seeing the AP reboot by itself one or times per day with the following message in the Event Log:
******SYSTEM STARTUP****** System Reset Exception -- Special Reset Code 00000002 100F11EE 6FF07FF5 0 0 0 0 0 0 0 Software Version : CANOPY 16.0.1.1 AP Board Type : P13 Device Setting : 900MHz MIMO OFDM - Access Point - 0a-00-3e-45-a0-46 - 906.00 MHz - 5.0 MHz - 1/16 - CC 85 - 5.0 ms - North America/United States FPGA Version : 020519; 10/15/2019 : 10:12:59 CST : :Time Set 10/15/2019 : 10:13:14 CST : :Board Temperature: 10 C / 50 F 10/15/2019 : 10:13:17 CST : Acquired sync pulse from Timing Port/UGPS
Any ideas what this error means? None of our other 900MHz 450i AP's running v16.0.0.1 or v15.2.1 are experiencing this. I upgraded this AP to v16.0.1.1 because of this message and no luck. Any suggestions?
That didn't do the trick. Still seeing this weird reboot. I was hoping the debug "code" ment something to the engineers and they would have replied by now. Rolling this back to 15.2.1 to see if it still happens.
Software Version : CANOPY 16.1 AP
Board Type : P13
FPGA Version : 060419;
12/31/2015 : 18:00:00 CST : :
01/01/2016 : 00:00:00 UTC : :Time Set
Board Type : P13
10/25/2019 : 13:41:28 CST : :Time Set
10/25/2019 : 13:41:43 CST : :Board Temperature: 9 C / 48 F
Reverted to v15.2.1 and still happening. AP rebooted itself 5 times since my last post.
Every time it comes back up, there is the same message:
Anyone at Cambium have any ideas on this? Surely someone there knows what it means, and if it's fixable in software or if this is just a faulty piece of hardware. None of our other 15+ 900MHz 450i AP's are doing this.
To me, going through the Cambium support channel is worse than going to the dentist.
Brian - We've dug into the messaging and it looks like this might be a hardware fault... I am afraid you'll need to open a ticket with support and get the unit RMA'd. We would like to see this unit. We will escalate the ticket and ensure this is a better experience than the dentist chair!
