I would ike to see changes take effect immediatly. I hate having to reboot :evil: and lose all connectivity every time I make a change - even small ones. Even a windows that says “Are You Sure You Want To Make The Changes?” would be great. :lol:
Thanks.
acherman wrote: I would ike to see changes take effect immediatly. I hate having to reboot :evil: and lose all connectivity every time I make a change - even small ones. Even a windows that says "Are You Sure You Want To Make The Changes?" would be great. :lol:
Thanks.
Or at the very least if a reboot IS necessary, then make it so the unit doesn't have to go through the 25-30 second system self-check proccess. That would speed up reboot times...
