not been aple to access an sm and ap module
i was doing a banch upgrade to an AP module from relase 3.2 to 4.1 after the burnfile command i issued a reset command insted of issuing an fpga_conf command since then i was not able to access the uint i did use the reset plug but nothing is happening can some one tell me if there is a way to to reset this unit or fix the issue?
thanks
adel suliman[/quote]
