has anyone used these and do the actually WORK and work well?
i am using syninjector and syncpipe on two towers. works great.
I use the same setup as Charles.
BTW Charles, I have sent you a couple of PMs asking if you would share your Cacti Traffic Reporting Template, would you? Even if it is not finished we would like to have a go as it looks to be exactly what we want to do.
Adam
I would also like the Cacti templates & HOWTO.
Thanks in advance!
