OFDM-Backhaul Connectorized: Build-in antenna?
Hi guys, I searched like hell, but I didn´t found the right answer. So I come to you, hoping to get a helping hint.
If I use OFDM-Backhaul connectorized. Is it absolutely necessary to use external antennas or does those OFDM-BH have an integrated antenna too?
Thanks for your reply!
Kind regards Daniel
Kind regards Daniel
There is two version of BH OFDM :
- connectorized : means you must using external antenna
- integrated : means builtin antenna (23 dBm)
so if you don't want buy external antenna and the distance is enough (you can calculate with Link Estimator first before you decide which model that should you buy), you can use the integrated model
regards,
mrdlnf
