Hi
Apologies if asked before but does anyone know if there is an OID for GPS Sync status?
Need to monitor an AP that we're having some GPS issues with.
Thanks!
Hi
Thanks!
Hi colinhowlin,
cambiumToolbarSyncSource
Object ID: 1.3.6.1.4.1.17713.21.6.3.2.4
Syntax: INTEGER Constraints: 1 | 2 | 3 Access: read-only Status: current
Sync Source Status:
1 - GPS Sync Up,
2 - GPS Sync Down,
3 - CMM Sync
Device Allocation: AP
and
cambiumpmp80211GPSSyncStatusTrap
Object ID: 1.3.6.1.4.1.17713.21.0.2
Syntax: Sequence (Structure)
cambiumpmp80211GPSSyncStatusTrap cambiumToolbarGPSSyncState
Access: SNMP Notification
Status: current
GPS Sync Status TRAP. Trap indicating GPS Sync State change.
This state is indicated by the included value of cambiumToolbarGPSSyncState
Device Allocation: AP, SM
Is it what you are looking for?
Hi Fedor
Thanks for that.
I had found
1.3.6.1.4.1.17713.21.1.1.7.0
via a walk which seems to work when tested.
Am I ok to continue using this or would you recommend one of the two you listed?
Colin
is almost the same as you uses.
And second one just indicates changes.
Sometimes it can be useful.
Thank you.
