OIDs v4.4.2 CPU & Subscribers
Hello anyone know the OIDs for APs eMPM2000 running software V4.4.3 ?
I need to pull:
- CPU load
- Ammount of connected subscribers
Thanks in advance!
Miguel
I need to pull:
- CPU load
Thanks in advance!
Miguel
sysCPUUsage OBJECT-TYPE
		SYNTAX	   Counter32
		MAX-ACCESS read-only
		STATUS	   current
		DESCRIPTION
				"CPU Usage, measuring up to 0.1%
				Range: 0..1000
				Device Allocation: AP, SM"
		::= { cambiumPerformanceMonitoring 64 }
cambiumAPNumberOfConnectedSTA OBJECT-TYPE
		SYNTAX	   Integer32 (1..128)
		STATUS	   current
		DESCRIPTION
		"Number Of connected stations
		Device Allocation: AP"
		::= { cambiumRFStatus 10 }
 Thank you.
Hello, thanks for your information, do you have the OID Value?
CPU Usage - .1.3.6.1.4.1.17713.21.2.1.64
Amount of connected SMs - .1.3.6.1.4.1.17713.21.1.2.10
Thank you.
Hello thanks for the information, I'm running software version 4.4.3 and didn“t work.
Do you know for what software version runs with those OIDs?
Best Regards
Miguel
o in version 4.5.0 are not working the OIDs.
Could you pls review this?
Thanks in advance!
They work for me on 4.5 and 4.5.4.
Thank you.
This is still not working to me, the oids are ok?
