I have two canopy very old P8. I need to upgrade to 8.2.4 the actual canopy updater does’t work.
What it’s the procedure for upgrade those TFTP?? any how to guide???
You cant go to 8.x until that unit is running HW scheduling. You need CNUT 1 to get the unit to 4.x, then 6.x, then 7.x.
Then you can use an AP (P9) that can do both HW and SW scheduling, use CNUT 3.x to turn it into HW scheduling (the only way).
Then, you can upgrade to 8.1.5, then 8.2.4, then 9.0, then 9.3 if you want.
Paul, PDMNet.
Canopy Module Repair Division.
658 Old Dixie Highway
Vero Beach, FL 32962
772-564-6800 work
772-473-0352 cell
Hi, Paul
I try to get the CNUT 1 with no success also the older version that I have it’s the 7.3.6.
Any hint where I can get the CNUT 1 + 4.x + 6.X ?
Hi, I have been told that Motorola tech support will help you with the old files. If you get stuck, and they wont help, I will dig them up for you
-Paul
Paul McCall, PDMNet.
772-564-6800 work
772-473-0352 cell
