Onboarding a EX2016M-P switch to cnMaestro-X
Hey there.
We have a strange problem with our new EX2016M-P switch. We want to onboard it to cnMaestro-X cloud services. BUT the problem is we do not get any DNS services to work.
We added 8.8.8.8 as DNS-Server and we can also ping to our internal other switches. But we cannot ping anything, no Google, no nothing.
# show system info
Hardware Version                  : 01
Firmware Version                  : Diag-2.03.01
CNS Software Version              : 5.0.1-r4
PoE Firmware Version              : 3.56-1011-1
Model Name                        : EX2016M-P
Base MAC Address                  : bc:e6:7c:x
Switch MAC Address                : bc:e6:7c:x
Serial Number                     : Xxx
Manufacture Date                  : 2022-10-11
System Contact                    : support.cambiumnetworks.com
System Name                       : uvswitch1-1-ops
System Description                : Cambium Networks cnMatrix EX2016M-P Ethernet
 Switch
System Location                   : Cambium Networks 3800 Golf Road, Suite 360 R
olling
Logging Option                    : Console Logging
Device Uptime                     : 0 Days, 1 Hrs, 7 Mins, 56 Secs
Login Authentication Mode         : Local
Config Save Status                : Not Initiated
Remote Save Status                : Not Initiated
Config Restore Status             : Successful
Startup-config Date               : Wed Nov 15 16:48:09 UTC 2023
Reset Button                      : Enabled
Number of Reboots                 : 6
Last Reboot Reason                : Warm reboot
# show int des
Interface   Status    Protocol    Description
Gi0/1      Up        Up
Gi0/2      Up        Down
Gi0/3      Up        Down
Gi0/4      Up        Down
Gi0/5      Up        Down
Gi0/6      Up        Down
Gi0/7      Up        Down
Gi0/8      Up        Down
Gi0/9      Up        Down
Gi0/10     Up        Down
Gi0/11     Up        Down
Gi0/12     Up        Down
Gi0/13     Up        Down
Gi0/14     Up        Down
Ex0/1      Up        Down
Ex0/2      Up        Down
mgmt0      Up        Down
vlan1      Up        Up
# show ip int
mgmt0 is up, line protocol is down
Internet Address is 192.168.0.1/24
Broadcast Address  192.168.0.255
vlan1 is up, line protocol is up
Internet Address is 192.168.255.81/24
Broadcast Address  192.168.255.255
# show cnmaestro
Currently managed by       : cnMaestro
Management Agent           : Enabled
cnMaestro URL              : https://cloud.cambiumnetworks.com
Certificate Validation     : Full
Connection State           : Connecting
Account ID                 :
Last Action                : Connect failed: Timeout was reached
Last Sync                  : Never
# show ip route
Codes: C - connected, S - static, R - rip, O - ospf,
IA - OSPF inter area, N1 - OSPF NSSA external type 1,
N2 - OSPF NSSA external type 2, E1 - OSPF external type 1,
E2 - OSPF external type 2
S 0.0.0.0/0  [1/1] via 192.168.255.1
C 192.168.255.0/24 is directly connected, vlan1
# show ip dns name-server
  Name Server IP Table
  Index  Address-Type   IP-Address
     1     ipv4          8.8.8.8
Andy thoughts what could be the problem?
Greetings from Cologne!
Michael
There is a NAT on 192.168.255.0 to go outside ?
As far as I know we have no NAT on this subnet.
Then you have the reason for not being able to access the Internet.
You simply don’t have external routing because there is no address translation :wink:
It was a firewall issue. The subnet was not allowed to talk to the outside internet. Switches are now in Sync with the portal.
