Open Status Page of element not active
Hello All,
After installation of Prizm 3.1 I noticed that there’s no “Open status page…” option available from menu of each element. Could you explain what could be a reason for this?
Best regards,
Mariusz Glinski
Sprint Ltd
you must enable Web-Proxy
Sorry i have the same Problem. Where i must enable the Web-Proxy?
Enable it in the Prizm administrator console (located in the start menu under Windows - not sure on Linux).
hi, we are running Prizm on a linux machine.
I believe what you’d want to do is locate the prizmconfig.xml file in the config directory in the prizm install folder.
Find:
class=“com.mot.canopy.prizm.services.elementproxy.ElementProxyService”
Make sure it is set like above. Set enabled=“true” to enable the proxy service and set doubleproxy=“enabled” to allow you to view downlink elements from a proxied page (ie if you’re in an AP status page you can bring up element status pages via the LUID on the web interface).
