In which temperatures ranges cambium equipment can work normally. For example Cambium Force 180 radius.
The datasheet for each product (found on our main website) should show the operating temperature range. For example, you can find the datasheet for the Force 180 here:
…which says:
Temperature: -30°C to +60°C (-22°F to +140°F)
Thanks Simon!
I’ve been seeing that all teams have a 60 degree heat limit. Please correct me if there is anything different to this
I’m afraid I don’t know the answer to that - you’ll have to check the datasheets for the products you are interested in.
