So I got the new cnMaestro On-Premises edition, and I am liking it, but I'd want to configure for autoprovisioning using one of the DHCP Options. No luck there, but if I manually add the URL for the new cnMaestro system, it works perfectly.
I think I have my Mikrotik correctly configured to hand out both Option 15 and 43, and I've tried with f/w 2.6.2.1 and 3.0 (release versions only - is that the issue?)
Here's my Mikrotik config for DHCP Options, and both options are active on the relevant networks:
/ip dhcp-server option
add code=15 name=maestro value="'domain.com'"
add code=43 name=cnmaestro value="'https://cnmaestro.domain.com'"
Obviously, my domain is not 'domain.com', but I made sure to use the single-quotes around my string values, and the name does resolve (remember, if I explicitly give the full URL, as listed in Option 43, it does work).
Any brave, adventurous souls already figured it out?
