Dear all canopy tech support and mastering in Canopy wireless
I have a problem in P10 Bh’s
in P10 Bh ,the power level can we make it into 25dbm, i tried it before make 25dbm but after i save changes n reboot the Bh,and i check the configureation in radio it still 23dbm.
are there any script or tools that can make the P10 bh become a great power ?
please tell us
thx
It’s dependent on Region. So you’d have to change the REGION setting to that of the US or Canada to get a TX power of 25db.
if i choose the region is other,can it 25db?
Frothingdog.ca wrote: It's dependent on Region. So you'd have to change the REGION setting to that of the US or Canada to get a TX power of 25db.
I already tried it to choose the region become US and Canada,it's still 23db
it can be 25db..cause in the module range from 5 - 23db.
I think the 2.4 Ghz platform is the one that transmits at 25 dbm…
moinavery wrote: I think the 2.4 Ghz platform is the one that transmits at 25 dbm....
If in the 2.4Ghz platform it can..How about BH 5.7?
can it setting to 25dbm the TX power ?
5.7 radios set to Canada will will go up to 25db. Change the region to Canada save and then reboot. Then change the Power level to 25 and then save and reboot.
However if it’s a 5.4 radio It’ll only go up to 23db when set to Canada
is this only for P10 BH??
I tryed on P10 AP and SM, mas tx is 23dbm…
it applies to all the 5.4 radios, AP’s, SM’s and BH’s
