We have a few 24vdc solar sites with P100 SMs that I'd like to just swap out with ePmP CPEs (non-sync). We cut the ACpower cord off the standard P100 PoE power supply and just connected 24vDC the dongle and then we plug the dongle into a switch and then plug the P100 into the dongle (to radio) as we normally would. Will the dongle pin out work with the ePmP so we can just swap the radios out and plug the ePmP into the TO RADIO jack in the same way?
The PMP100 and ePMP power supplies and pin-outs are the same. You should be good to go.
