We have released a patch to fix two bugs that have been reported.
The first fixes a potential issue when saving project files and the second fixes an error when recreating a link which has been previously deleted.
To install the patch on Windows:
- - Download the patch files from http://linkplanner.cambiumnetworks.com/patches/Windows/4.3.10/
- Close LINKPlanner
- Open the LINKPlanner installation directory in Explorer (e.g. C:\Program Files (x86)\Cambium Networks\LINKPlanner)
- Navigate to the folder "link_planner\model"
- Place the patch files in the folder
- You may need to download the files to a neutral location such as the desktop and then copy it into the folder. Windows doesn't like you replacing Program Files.
- Start LINKPlanner
To install the patch on a Mac:
- Download the patch files from http://linkplanner.cambiumnetworks.com/patches/Mac/4.3.10/
- Close LINKPlanner
- Open the "Applications" folder in Finder
- Right-click on "LINKPlanner.app" and click "Show Package Contents"
- Navigate to the folder "Contents/Resources/lib/python2.7"
- Unzip "site-packages.zip"
- Remove the "site-packages.zip" folder (if it is still there) to leave a "site-packages" folder
- Navigate to "site-packages/link_planner/model"
- Start LINKPlanner
