Several users have reported errors occuring after they have deleted items in their project. For instance:
Error details
Traceback (most recent call last):
File "link_planner\wxapp\bom_panel.pyc", line 420, in _on_has_extras
File "link_planner\wxapp\bom_panel.pyc", line 380, in product_type_and_region
AttributeError: 'PMPAccessPoint' object has no attribute 'product'
The attached patch fixes this bug. All users running v5.2.2 should apply the patch.
To install the patch on Windows:
- Download and unzip the attached patch
- Close LINKPlanner
- Open the LINKPlanner installation directory in Explorer (e.g. C:\Program Files\Cambium Networks\LINKPlanner)
- Navigate to the folder "link_planner\wxapp"
- Place the patch file in the folder
- Start LINKPlanner
To install the patch on MacOS:
- Close LINKPlanner
- Open the "Applications" folder in Finder
- Right-click on "LINKPlanner.app" and click "Show Package Contents"
- Navigate to the folder "Contents/Resources/lib/python2.7"
- Unzip "site-packages.zip"
- Remove the "site-packages.zip" file (if it is still there) to leave a "site-packages" folder
- Navigate to "site-packages/link_planner/wxapp"
- Place the patch file into the folder
- Start LINKPlanner
- main_frame.zip (55.3 KB)
