physical horizontal separation between 5.4 and 5.2
On one tower a new wisp installed some 5.4 canopy gear next to my existing 5.2. His equipment is located ~5-7ft horizontally away from my gear.
Is there any documentation on recommended physical separation between canopy equipment?
Vince
typically you want at least 25ft. of vertical separation nominally. horizontally im not too sure but i would assume 15-20ft.
With 25MHz of channel separation, sync, and config matching you should be fine.
