Hi all,
I need to know if there some firmware with ping watchdog function ?
Or if there some way , when AP losse connectivity or ping , itself can automatic reboot ?
I will appreciate all your comments.
thanks
Carlos
No, Canopy does not have that feature.
Take a look at this company
www.controlbyweb.com
They have 2 products that will ping a remote IP address and if ping responses are not received for a programmed number of times, it will activate a form C relay contact that can be used to power cycle the device connected to it.
The other product will switch an AC outlet socket under the same circumstances
The product is called WebRelay, and Webswitch
