Found a mac for a not on-boarded Cambium CPE in our network, and i need to track it back to an AP to disable it. This seems impossible, is it really? The radio is alive, it is renewing ip etc.
If you use managed switches, track the offending mac to the port. That should help narrow down the AP.
It is an option, but the cambiums systems should be able to report on every connected device.
Oh yes it will be on the AP, I’m just saying if you have many APs and need to track it down to which AP.
yes, cnmaestro should knvow this, but it does not…for now i have made a scheduled script that uses snmp to get all mac addresses from every AP and store it in a database, that way we can do a simple search when these things happen.
