Where can I find a plastic weather hood for an ePMP 1000 Connectorized radio? We plan to use it with a High Perf DP parabolic antenna, like the RDH4508B. The radio will be mounted on a pole using the standard ePMP mounting bracket.
I was hoping to get a hood similar to the one on a ePMP Force 100.
Does Cambium have a similar Hood that can be bought seperately to be used with the standard mounting bracket?
Any other alternatives?
