I connecting to PMP 100 SM by telnet but dont know how to change transmitter power (dBm) by command line.
Tried search "help" but no idea.
Thanks!
Thanks!
This is unsupported. You can change the transmit power of an AP in a number of different ways, typically through the Web GUI interface or via SNMP command.
So, is there any command to display curent transmit power?
Because the only way I can connect to PTP SM is telnet from router.
No, there is no supported telnet command to display transmit power.
