I see PMP software for the 450 and 430 has been released, but the documentation for WM 4.2.5 shows only 13.2 is supported. Will there be a WM update to support 13.3 ?
Is 13.2.1 supported in WM 4.2.5 HF1 ? The documentation indicates no.
I'm not sure what you consider 'supported' but I'm running WM4.2.5, and 13.3 devices show up just fine and appear to gather stats just fine.
