Are your devices showing 100% CPU usage? An issue was recently discovered where PMP 450 devices would reach 100% CPU usage and disconnect from cnMaestro while still being reachable. A fix for this has been developed and will be included in the 16.1 device firmware release.
"CPU Usage" is available on the first page you see when you access the device via its web UI under Device Information. It should be one of the first few rows.
Could you tell me a date, when will be this new software available?
The fix for this and the 100% CPU issue is inclued in the 16.1 release, which is currently in beta, and should be available as a stable release soon... maybe another month or two? If you loaded it up on some AP's and provided some feedback... you could help get it released sooner :-)
Unfortunately the problem is back.
The devices are on SW version: 16.1.
The cnMaestro is on Version 1.6.2-r11.
The problem began on 14 of January at 01:00 (You can see this on the attached picture). Do you know something about this problem? How should we handle this?
