The SM will not register when you have the tone enabled for aiming. You'll need to disable that and assuming you made no other changes, then it should go ahead and register.
Nathan
Nathan,
Thanks for the reply. I'm pretty sure it is disabled. Alghough I never heard a tone but I'm not sure these units have an internal speaker after further reading. Here is what I'm seeing on my tabs. So please let me know if I'm not looking under the correct tab.
PDA / AIM / Disabled as status state's Scanning and power level states it's not in alignment mode.
Tools / Alignment / Scan Radio Freqency only / Disabled: I found that I have to enable this and set it to my channel of 5780 to see my AP.
Tools / Alignment / Current Status is SM is in Operating Mode
Tools / Alignment / Detailed Beacon states Aiming mode is currently disabled.
So If I'm correct then the tone you are talking about is when I turn on the Scanning Feature to show my the signal strength. If there is another tab or somethig for the tone itself I'm completely blind as I'm not see it.
Correct, this will allow you to scan for the frequency but you'll want to disable this for normal operation. I would ensure that turning on this aiming mode did not mess up what your SM is scanning for. If it enabled all frequencies, that 450 will scan both 5.4 and 5.8 bands in 5, 10, 20, and 40mhz channels! That could take quite a while to register an SM.
I would set that SM to scan for only the frequency of that AP and uncheck all the other bands and channel widths you are not using. This is all assuming you are not having some kind of wierd Radius server setup issues.
Nathan
I did disable it and disabled the alignment tool.
As for the Radius statement. I believe the default ones are in place but I will have to verify this. Although the Authenticatino Key is set to Default and AAA authentication is disabled I didn't tihnk the Certs mattered. I maybe misunderstanding when they are used.
Earlier I did go to Configuration / Radio and under the 5.7GHz I only checked 5780 and 10MHz, saved it, and rebooted it, and I didn't see any difference.
I'm really tempted to default it and start from the beginning but I wasn't comfortable enough to do so. I may end up having to. I'm assuming even if it had a week signal (which I don't know what it was before) that it would still at least try to connect it but show red and bad or something. :(
I greatly appreciate your time and help but I'm gathering by the options your giving me that this should have just came back online. :) I'm open to any other idea. It'll give me stuff to check out tomorrow morning when I arrive back on site.
I wanted to add that the AP sees it as idle with a -67 dBm signal.
If you just took over the network and before you default that SM you'll want to know how these SM's are authenticating. In smaller networks it may just be a password (or no password) and in larger setups it may be authenticating against a Radius server back at your NOC. To be honest, I've never put an already registered SM into alignment mode and saw what it did to the settings. However, I can't imagine just turning that on and then off alone would cause this. If you have any other SM's on this sector and you're running the newest 13.3 firmware, it is supposed to allow you to export the settings and import the settings into another SM.
Not knowing the signal before doing this sort of makes ya wonder too, huh? What was the issue at this site? Hope I've helped some...
Proper, this particular will help you scan to the regularity nevertheless you need to disable this particular with regard to usual procedure. I would make sure that switching about this trying manner did not mess up just what your own SM is usually encoding with regard to. When that made it possible for most frequencies, in which 450 may scan the two 5. 5 in addition to 5. 8 groups inside 5, 10, 20, in addition to 40mhz channels! That could carry many years to register an SM.SM will not likely register if you have the actual develop empowered for trying. You should disable of which in addition to if it turns out you produced simply no some other modifications, next it will proceed to register.
______________________________________________________________________________________________
NoorAlamShahzad
We are getting similar issues with SM's going offline and just scanning for no reason. They will be fine one day then a customer calls and we log into them from the ethernet side and they will just scan. They will not link to either of our 5.8 Aps. So far we have had 5 in the last 2 weeks just stop working and only scan.
snorthway, I'd need more info to help you. The SM's are scanning and not finding the AP for a reason. What is the RSSI on the SM before they started scanning? Does the firmware of the SM match the AP? Do you have LOS? Are these SM's located on the edge of the sector? Did your authentication change? Does the scanning frequency match the AP freqency and channel width? etc, etc.
The RSSI on them would range from -65 to -75 we wont put them in higher than -75. Software on the AP is 12.1.3 and on the SM's are 12.1.3 these seem to be the ones scanning and our new ones are running 13.1.3. I know we need to upgrade the whole network. Trying to work some kinks our of CNUT and why I cant see our second AP. We are not running any authentication at present. We are new to Cambium and two of us just bought it to offload customers from out airspan 3.65 but this is working so well we are going to keep it. LOS is great nothing in the way of any that have went offline.
And as far as the Freq yes they match and the channel width is also correct
How far away are the SM's from the AP- is your AP distance setting within the range of the SM? Do you have other SM's on this AP that work fine? I know this is a pain but can you take the SM's from the customer and go closer to the AP site to rule out signal issues. Obviously, if you are standing directly underneath the AP with the SM and it connects just fine, then you know its a signal issue. From here, depending on what you find, I would definately update the firmware to 13.2.1 as it adds many features and improvements. Before I go to the tower with SM, I'd try another SM or default the SM to factory and start over.
From my experience with the 450 3.65 setups, there are only a handful of reasons why the SM just sets there and scans: 1. you don't have a good enough signal -too far away, noise, edge of sector, etc. 2. you're outside of the max distance set on the AP. 3. You are scanning the wrong frequency or channel width or improper country code selected. 4. you have the wrong authentication between the SM and AP (even though I think it would give an error if it tried connecting). 5. LBT hits on the AP stopping transmission -although this would affect all SM's on the sector. 6. Target recieve level set too high or SM external gain set to high (maybe someone adjusted these without know what they do?)
I know we need to upgrade this is 5.8 not 3.65. The SM's will not link no matter how far from tower we are we have tried syncing them to other AP and still nothing. Other SM's running same firmware working fine. we have defaulted it but ordering the pinout to reset via that way to see if it is just somehow hosed up.
