Is there anyone else noticing Rugged High Gain 450 SUs are coming up at 6dbm transmit power? We are seeing this too often. A fix we have is relenquishing the grant from the AP or associating to another sector and then back to our original sector.
We are using the On-Premesis version on Maestro and firmware 16.1.2 (Beta-2).
I have forwarded this to our support team
jBrantley,
My initial reaction was, you are likely running into a Regulatory limit on the SM's transmit power prior to an authorized grant from the SAS. But your fix/workaround is interesting. I will try to reach out to you via private channel for more discussion
BTW, I assume you mean to say you are running 16.2.1 BETA-2?
Al
Correct, yes 16.2.1 BETA-2
I figured out my issue. I was entering in my EIRP request wrong.... thanks for the help.
Thanks for posting this. This information may be useful to another operator that finds himself in a similar situation.
