Does anybody can suggest a flat pannel atenna that has the same specs as the Mars but cheaper? I have some PMP 450 SM connectorized radios, but don't have enough antennas. Anybody knows about another possibility?
MA-WA56-DP25N
4.9-5.875 GHz Dual Polarized/ Dual Slant Antenna
MARS 5 GHz Dual Polarized Antenna designed to provide full coverage for the 5 GHz frequency band.
Additional Features:
- Dual slant if mounted diagonally.
- Efficient and stable performance.
- High gain/size ratio.
- Light weight and durable construction.
- UV protected radome made of polycarbonate suitable for harsh weather installations.
- Easy mounting allowing Az/El adjustment and 45° turn installation.
