PMP 450 SM Dropping
Running PMP AP 450 at 5G for about a year. AP and all clients running fw 13.4 . All was well with it until I added the 32nd 450SM. Now there is always 1 SM that is dropping connection with high re-reg attempts. When I reboot the AP the misbehaving SM becomes stable and a different SM begins intermittent connection. Any ideas?
Hello,
Can you please send the engineering.cgi file from your AP when all 32 SMs are registered to:
solutions@cambiumnetworks.com
We test the PMP 450 and the PMP 450i in a 238 SM setup and have not seen the issue that you have described.
Best,
Cambium Jonathan
did you do a link test and also run a Spectrum test?   we had the same issue and had to update channel Frequency
Never have 32.  31 solidlyd stable.  When add 32nd one of the stable 31 drops.
Hi, Do you use authentication method as ‘RADIUS’ for the SM’s ?
Thank you for responding.  No.  We are not currently using authentication on the specific AP that is having the issue.
Hello, Can you please send the engineering.cgi file from your AP when problem occurs and also the engineering.cgi of SM (which is unable to register). solutions@cambiumnetworks.com
