PMP_450 SM upgraded default to 20 MBPS .
HI,
Kindly be informed that the i have upgrade the speed to deafault to 20 Mbps by applying license , but still am getting same speed 4Mbps ,so please advice .
Have you changed default QoS values in settings (Configuration => QoS) ?
Agree that based on your screen capture, the key did what it was supposed to.  I would look at the MIR settings of the radio.  This should fix the issue.
Hi Sameer,
By looking at the screen-shot, I see that the license is applied to the radio, so no issues there.
The radio capacity is now 20Mbps.
May I know how many SM's are connected to the AP?
Are you only facing this issue on this SM?
Could you please share the screen-shot of the QOS configuration from the radio.
Also please run the link capacity test and share the screen-shots for the same.
Under Tools → Link Capacity Test
Run Link capacity test with Bridging and with MIR.
Please send these details to support@cambiumnetworks.com along with your contact details.
Regards,
Hardik Patel
Its new inatallation now only one SM is connected and its almost 3.34 mile are signal we are getting 79 .
is there any other option to incrsea the signal .
Are you using a bare SM? If yes, you could try using a reflector dish with it and that should help quite a bit. Is the line of sight between the AP and SM clear? What sort of antenna are you using at the AP and have you tried changing the AP's antenna alignment?
