Which throughput is associated to SM model number C036045C009A?
In the sheet this model number is non mentioned.
Cambium PMP 450 Subscriber Module 20Mbps Throughput, however if you buy a software license key you can make it uncapped
But from PMP 450 data sheet 20Mbps seems to be related to -03A and -07A.
Hello,
There is not a SM model associated with part number C036045C009A.
C036045C003A - 3.55-3.8 GHz PMP 450 Subscriber Module, 20 Mbps
C036045C007A - 3.55-3.8 GHz PMP 450 Connectorized Subscriber Module, 20 Mbps
-Garrett
so c036045c009a what is it?
is a 3Ghz model?
c036045c009a does not exist.
These are the only 450 3.65GHz part numbers available.
C036045B001A | PTP 450 3.65 GHz END – Integrated |
C036045B002A | PTP 450 3.65 GHz END - Connectorized |
C036045B003A | PTP 450 3.65 GHz END – Integrated – DES Only |
C036045B004A | PTP 450 3.65 GHz END – Connectorized – DES Only |
C036045C001A | 3.55 - 3.8 GHz PMP 450 Subscriber Module, 4 Mbps |
C036045C002A | 3.55 - 3.8 GHz PMP 450 Subscriber Module, 10 Mbps |
C036045C003A | 3.55-3.8 GHz PMP 450 Subscriber Module, 20 Mbps |
C036045C004A | 3.55-3.8 GHz PMP 450 Subscriber Module, Uncapped |
C036045C005A | 3.55 - 3.8 GHz PMP 450 Connectorized Subscriber Module, 4 Mbps |
C036045C006A | 3.55-3.8 GHz PMP 450 Connectorized Subscriber Module, 10 Mbps |
C036045C007A | 3.55-3.8 GHz PMP 450 Connectorized Subscriber Module, 20 Mbps |
C036045C008A | 3.55-3.8 GHz PMP 450 Connectorized Subscriber Module, Uncapped |
C036045C014A | 3.55 - 3.8 GHz PMP 450 High Gain Directional Integrated Subscriber |
Message or email me at gkellner@converge-tech.com and I can help find what you are looking for.
-Garrett
This model is not sold to the public. Please private message me if further discussion on this is required.
Matt
