will the pmp 450i work on cmm3 when the voltage is only 30 volts
and will it work on the coverage extenders ra5000n
Hi Kay,
PMP450i requeires 56V input so it will not be power up by CMM3. You can use CMM4 for the Synchronization and Power.
Regards,
Sanjay Kumar.
@Kay wrote:will the pmp 450i work on cmm3 when the voltage is only 30 volts
Is this a PMP450i 900MHz SM? If so, then that uses the standard 30V power supply.
