I'm looking for the oid for total data being transmited up and down from the AP in bytes or bits.
I looked here but couldn't find it.
You can find the latest Mib files in the below site :
https://support.cambiumnetworks.com/files/pmp450/
You can monitor the inoctect and the outoctet count. The OID's are as follows :
.1.3.6.1.2.1.2.2.1.10 - inoctet count
.1.3.6.1.2.1.2.2.1.16 - outoctet count
When you enter these values, you would get 2 values like inoctect.1 and inoctet.2. inoctet.1 is the ethernet stats and the .2 is the RF stats.
Please let me know if this is what you are looking for.
Regards,
Vivek Gupta
Yep that's what I was looking for thanks.
Also does that output in bits or bytes?
This value will not be in bits or bytes, It only gives the value of the number of Octets received and transmitted.
Regards,
Sanjay Kumar
IF-MIB::ifHCInOctets.1
IF-MIB::ifHCOutOctets.1
