The GUI of PMP100 SM after upgrade to 13.1.2 shows a tab Tools-Alignment with Aiming Configuration set od parameters. It seems the latest PMP Solutions User Guide 12.1 does not explain these parameters.
Can anyone explain these parameters or does know where I can find a supplementary description?
What is an idea to use the aiming feature neglecting a beacon, which Scan Radio Frequency Only Mode “Enabled” does suggest?
Please note, the Tools-Alignment Tool is another tab with jitter and power level bar indicators.
