Hi All,
I need to know if there is a way for the SM (450 / 450i) to filter the traffic based on VLAN tag. Exapmle: I need to pass traffic with VLAN tags 2, 6, 10 only and block all other traffic in & out.
Also, I need to know the maximum aggregate capacity can be carried by PMP450/ 450i per sector for different channel widths.
Thanks.
Hi Mohamed,
Yes, there is a way to filter traffic based on VLAN tags.
VLANs need to be enabled on the AP, to filter VLAN tagged traffic.
In "Configuration -> VLAN" page of the SM and AP,
- Set "Dynamic Learning" to "Disable"
- Add the VLANs you would like to pass through, to "VLAN Membership Configuration" table.
For site-specific link range and throughput planning information, see:
https://support.cambiumnetworks.com/files/linkplanner
Best Regards,
Balaji
