Wondering if anyone else has seen this. We recently upgraded a sector to 16.0.0.1 for testing prior to rolling it out to our entire network. The firmware seems to run well, except scripts don't seem to work from cnMaestro. I know a few script names changed, so I started over from scratch using an existing radio on 16.0.0.1 as a template.
One example is location
"userParameters": {
"location": {
"siteName": "${SITE_NAME=CustomerName-CITY-Cambium}",
"siteInfoViewable": 0,
"siteContact": "${SITE_CONTACT=NAME_PHONENUMBER}",
"siteLocation": "${SITE_ADDRESS}",
"height": ${ANTENNA_HEIGHT}
None of these have changed since prior to 16.0.0.1. But when I push this config to a unit running 16.0.0.1, it sets the siteContact, siteLocation, and heigth. However siteName does not get applied and remains what it was.
A second example is QoS Settings. These did have some chagne names, new ones added, etc. So I updated my JSON script to this:
"qosConfig": {
"uplinkBurstAllocation": 0,
"largeVCQ": 0,
"prioritizeTcpAck": 1,
"sustainedUplinkDataRate": ${UPLOAD_IN_Kbp},
"sustainedDownlinkDataRate": ${DOWNLOAD_IN_Kbps},
"downlinkBurstAllocation": 0,
"maxDownlinkDataRate": 0,
"maxUplinkDataRate": 0
"smQosConfig": {
"highPriorityDownlinkCIR": 0,
"mediumPriorityDownlinkCIR": 0,
"smPrioritizationGroup": 0,
"dataChannelCount": 1,
"ultraHighPriorityDownlinkCIR": 0,
"mediumPriorityUplinkCIR": 0,
"ultraHighPriorityUplinkCIR": 0,
"highPriorityUplinkCIR": 0,
"lowPriorityDownlinkCIR": 0,
"lowPriorityUplinkCIR": 0,
"highPriorityChannel": 1,
"bCastMIRUnits": 0,
"bCastMIR": 0
Before I only set highpriorityCIR and lowpriorityCIR under smQoSConfig. However after upgrading to 16.0.0.1 it would no longer push the qosConfig:{sustainedUplinkDataRate}. Once I added in all of the smQoSConfig from the active unit without changing anything under qosConfig, it now sets those two values. However, even though the script sets dataChannelCount:1, after the scrip pushes the radio reboots and still is configured for two data channels.
Going to keep beating it into a brick wall, but hoping someone has seen it and knows a quick fix.
