Hi, I need PMP450 Firmware 13.1.2 version. This file is no longer avalaible on the Cambium Networks website. Can anyone helpme out with this? Thank you so much.
You should be able to get it from customer support:
As Yonghao mentioned, you can get 13.1.2 from customer support. However we strongly recommend you use 13.2.1 unless there is a specific reason you would like to use 13.1.2.
Sriram
I need this firmware, because is the only one that haves 5900Mhz frecuency, and I need specifically work on it. I dont know another firmware for this equipment with this frecuency.
