Does anyone have a spec sheet on the new sector? The one I found online does not have the actual dimensions of the new sector itself.
I have that. Dimesions of sector are not right.
Ha I just noticed that. 14.5” is a bit wide for the sector.
Hopefully someone at Cambium can make the correction to the spec sheet.
Garrett
I will get this corrected... hopefully it'll be posted tomorrow!
Thanks.
Please make sure dimensions and weight is listed. I think the current sectors are way to heavy. Thanks!
The spec sheet has been updated... you may need to refresh your browser to see the updated file.
I included it here also to make it easier for you.
Thanks for finding this, it was a big help to make sure we're updated and accurate!
- Spec_PMP_450i_AP_July2016_v2.pdf (1.12 MB)
