Could you please tell me if PMP450i AP are delivered with mounting bracket? or they have to be acquired separated?
I’m planning to order following code C050045A004 5 GHz PMP 450i Connectorized Access Point (No Encryption)
No. Unfortunately you have to purchase a mounting bracket separately. KP Performance sector antennas often come with a universal bracket that will work though, if you are using them.
If you purchase the Integrated Sector 450i Access Points, however, they do come with all brackets necessary to mount to a pole.
In most cases, this is the preferred deployment scenario, because the 90 degree sector antenna is fully integrated and to the performance specifications as indicated in the data sheet.
In this case, those would be part numbers:
C050045A005C
C050045A006C
C050045A016C
C050045A007C
C050045A008C (this is the “No Encryption” model)
If you need the connectorized version, then Jacob is correct, you’ll need to purchase the mount separately. The Tilt Bracket Assembly is commonly used for this, part number N000045L002A.
Thanks a lot Jacob and Matt.
