When will we see DIN mount units with POE and sync outputs?
Thank you for your question.
cnMatrix switches that have PoE with Sync are in design now. These switches will be a part of our WISP family of switches, the cnMatrix TX line of switches. (still working on the 'TX' brand. It could change)
DIN rail mountable switches are also a part of our consideration, but we don't have an estimated schedule for availability yet.
When engineering to add POE functionality, are you considering allowing multiple voltages on the switch, so we can power ePMP1k and 3k AP’s from the same switch?
