Port Configuration problem - CnMaestro cloud
When we try to edit a port in our CnMaestro portal, we go to Monitor and Manage, select the desired switch, and click on the port we want to edit. Then we select Action and Port Configuration. However, the changes we make are not applied, and when we re-enter the port configuration, no modifications have been saved.
Hi @Enkeled_Alla ,
This is a known issue and it has been fixed. We will release the build in couple of days.
For now, can you please try to configure the ports from switch group level.
//Indra
