We were just looking to move into a new area and it appears there is already an existing wireless company.
If they are running vertical polarization would it be possible for us to co-exist and operate fairly well?
You will need to know their settings for
DL%
Control Slots
Max Distance
Then either set your AP’s to use the same settings or use the Frame Calculator Tool to get your AP’s in sync with theirs.
Also, since they are using V-POL, you will see better performance if you use H-POL and try to use alternate frequencies.
It does not appear they are using Canopy though.
Any idea what they are using?
No I’m not sure, if I were to guess it’s Trango based on the CPE I saw but I’ve never seen one up close so I’m not 100% sure.
